MS G3 Series
5-10 kW | Single Phase | 3 MPPTs
IP66
20A
The MS G3 single-phase inverters of 5-10kW provide powerful and versatile solution options for residential buildings. This model boasts 3 MPPTs for various complex rooftops, thus leading to high power efficiency. The ultra-low 50V startup voltage allows inverters to kick in earlier during the day and presents more power generation. In addition, by supporting up to 20A DC max. input current per MPPT, the MS G3 Series is ideal for high-power modules, which makes full use of power generated and presents lower LCOE. Importantly, PID (potential induced degradation) recovery function is supported for better module performance. The inverter also takes safety measures including optional Arc-Fault Circuit Interrupter (AFCI) and Type II Surge Protection Device (SPD) on both DC & AC sides to protect the system from electrical fire and lightning hazards in extreme environments.
24-hour load consumption monitoring
Optional AFCI & rapid shutdown
50V startup voltage
Elegant and compact design
IP66
20A
Smart Control & Monitoring
Users can enjoy smart energy management with 24-hour load consumption monitoring enabled by GoodWe HomeKit 1000 or GM10001. Dry contact in the inverter is available for various home load controls. High-power loads such as HVAC and heat pumps can be intelligently controlled through the inverter.
Smart load control with dry contacts
Friendly & Thoughtful Design
MS G3 Series is equipped with fanless natural convection cooling to realize quiet operation for users' peace of mind. Software updates can be relatively easy and quick by using a USB. The elegant and compact design is perfect for indoor installation.
Software updates via USB
High Power Generation
MS G3 Series is designed to achieve the maximum yield and present lower energy costs. The considerably low startup voltage of 50V means that the solar system can generate power from dawn to dusk to harness as much solar energy as possible regardless of irradiation and weather conditions. The high input current maximizes  energy generation thanks to its compatibility with high-power PV modules.
97.9%
97.9% max. efficiency
3
3 MPPTs
50
50V startup voltage
20
Up to 20A max. DC input current per string
GW10K-MS-30
Max. Input Voltage (V):
20
3/1
Weight (kg) :
19
Nominal Output Voltage (V) :
220/230/240
GW8500-MS-30
20
3/1
Weight (kg) :
19
220/230/240
GW7000-MS-30
20
3/1
Weight (kg) :
19
220/230/240
GW6000-MS-30
20
3/1
Weight (kg) :
19
220/230/240
GW5000-MS-30
20
3/1
Weight (kg) :
19
220/230/240
Installer
