SMT-US
50/60kW ∣Up to 6 MPPTS∣Three Phase
SMT-US | GoodWe US
180V-980V wide input operating voltage range
Fuse-free design for simple maintenance
The GoodWe SMT-US Series inverter is ideal for medium and large-scale commercial installations. Harvest maximum solar energy and generate environmental-friendly power for an increased return on investment. Its unique fuse-free design makes it exceptionally easy to maintain for operators, saving time and money. The superb safety design provides reliable protections in outdoor installations and guarantees stable usage and generation even in extreme conditions.
Up to 6 MPPTs for ultimate design flexibility
150% DC input oversizing
Type II Surge Protection for both DC and AC
SMT-US | GoodWe US
Fully Integrated Design
The inverter can accommodate aluminum wires on the AC output circuit to reduce balance-of-system costs on ground mount systems. The fuse-free design of the SMT-US significantly reduces maintenance considerations and increases reliability.
AC terminal compatible with aluminum cables
Fuse-free design
Maximum Return on Investment
The SMT-US's 180V-980V wide operating voltage range allows the PV system to begin producing power earlier in the day, fully maximizing solar energy generation. With a max. 15A DC input current per string, the SMT-US Series is compatible with many high-power modules, giving integrators greater versatility in module selection and system design. Up to 6 MPPTs guarantee optimal energy production, even in areas with shading, delivering best-in-class ROI for commercial systems.
980V
6
Up to 6 MPPTs
150%
110% AC output overloading
GW50K-SMT-US
Max. Input Voltage (V)
1000
Max. Input Current per MPPT (A)/Number of Strings per MPPT
5/2
Max. Efficiency
98.5%
Nominal AC Grid Voltage (V)
480, 3L / N / PE or 3L / PE
GW60K-SMT-US
1000
6/2
Max. Efficiency
98.5%
Installer
