WHAT MAKES GOODWE RELIABLE ?
Only the most reliable and prominent components after rigorous quality control are selected for the inverters. About 90% of the components come from World Top 500 companies, because quality is a top priority.
Incoming Inspection
All the incoming raw materials will be sample inspected by certain proportion based on ISO9001. The sample components with inferior quality will be excluded along with the whole batch.
ICT Test
In-Circuit Test ensures that each piece of PCBA boards is of perfect working conditions
ISO Test
ISO functionality Test is designed to test insulation and electric leakage for safety regulations in various countries. The samples are in grid-tied simulation during the test to guarantee product safety.
100% Test (Burn-in)
6-hour aging test will be operated on the product samples under the enclosed humid environment where it faces a 50 degree celesius environment. Ensuring the GoodWe inverter will maintain it's maximum performance without failure.
ATS Test
All the inverters will be tested through AC&DC Power sources to simulate different weather radiation, load and grid condition of various countries.
Final Test
Before packaging, every inverter will go through a final test for performance record and identification.
We are continuously striving to improve the quality of our management systems that enables GoodWe to produce safe and defect free products while ensuring products and performance will be of customers satisfation.
Certificate
Certificate
Certificate
