LVMT Series
30-50 kW | Three phase | 4 MPPTs
Low voltage
South America
Developed as an efficient response to South American market needs for low-voltage inverters, GoodWe’s LVMT series inverter is suitable for medium and large-scale commercial rooftops or ground-mounted solar PV systems where maximum versatility and profitability are important. With its compact design and power boost function, GoodWe’s LVMT series can provide an extremely high efficiency of 98.8%, thus offering a faster return on investment.
String level monitoring
Up to 180% DC input oversizing & 110% AC output overloading
Full-load running at 50ºC
Power line communication
Low voltage
South America
Four MPPTs Maximize Output
Improve your energy harvest with four MPP trackers to minimize output losses caused by partial shading and other mismatch effects.
4 MPPTs
Up to 98.8% Max. Efficiency
High Generation
With 180% DC input oversizing capability, the LVMT allows users to significantly expand the solar array and drive increased power output even under low solar radiation.
180%
DC INPUT OVERSIZING
AC OUTPUT OVERLOADING
GW30KLV-MT
Max. Input Voltage (V):
800
33/33/22/22
4/3-3-2-2
Max. Efficiency :
98.7%
Nominal Output Voltage (V) :
220, 3L/N/PE or 3L/PE
GW35KLV-MT
800
33
4/3
Max. Efficiency :
98.8%
GW50KLV-MT
800
44
4/4/4/4
Max. Efficiency :
98.7%
Installer
