ESA Series
5 kW+10.8 kWh | Single phase| Home storage solution (LV)
All-in-one
Pre-wired
GoodWe ESA Series is an all-in-one solar and storage solution that integrates the inverter, battery charger, UPS-level switching, and battery enclosure into a pre-wired modular system for easier and faster installation. The compact, elegantly designed, and robust unit is IP65 rated, so it can be mounted either inside or outside withstanding all weather conditions and brings a reduction of installation time of up to 50%.
<10 ms UPS-level switching
IP65 ingress protection
All-in-one
Pre-wired
Friendly & Thoughtful Design
The exquisite ESA series occupies less space and offers neater installation than a split storage system in order to create a high-performance system that is aesthetically pleasing. This masterpiece perfectly integrates with a 5 kW hybrid inverter with a 10.8 kWh Lithium battery inside. The lightweight, maneuverable system makes installation a breeze, and its aesthetically appealing design styles up your home interior.
All-in-one modularized design
Pre-wired components
Appealing design adding style to your house
The smart hybrid system has been designed to flexibly suit user’s needs.  The modular system is expandable with battery storage to allow for easy upgrades and future extension of the power system.
100A maximum charging and discharging current
10.8 kWh battery capacity
Expandable storage
GW5048-ESA
40~60
90/100
14/14
4600
Installer
