BH Series
3-6 kW | Single phase | AC-coupled retrofit inverter (HV)
Fanless & quiet
Elegant & compact
The GoodWe BH Series inverter is a single-phase, AC-coupled retrofit inverter compatible with a wide range of high voltage batteries from 85V to 460V. It is designed to maximize self-consumption with a UPS-level switching backup function. The pre-wired communication cables and AC connector’s Plug & Play simplify installation, operation, and maintenance.
Quality and robust components
IP65 ingress protection
<10 ms UPS-level switching
Fanless & quiet
Elegant & compact
Friendly & Thoughtful Design
BH Series is equipped with fanless natural convection cooling to realize quiet operation for users' peace of mind. The elegant and compact design is perfect for indoor installation.
Elegant and compact design
As a single-phase, AC-coupled retrofit HV inverter, BH Series can upgrade existing on-grid PV systems to storage systems.  With a wide battery voltage range of 85-460V, the inverter fits users' needs flexibly and makes the energy system construction much more effortless. The power supply ability in backup mode supports large loads for critical operations.
Strong backup power supply
Wide battery voltage range 85~460 V
GW3K-BH
85~400
32/32
230
3000/3300 (CEI 0-21)
3000
GW3600-BH
85~460
25/25
230
3600/3960 (CEI 0-21)
3600
GW5000-BH
85~460
25/25
230
5000/5500 (CEI 0-21)
GW6000-BH
85~460
25/25
230
6000/6600 (CEI 0-21)
6000
Installer
