Sunshine Series
BMT-S1/032A | 92W |PV Building Material
Modular Design
Fire Resistance
GoodWe Sunshine Series are solar tiles that accommodate a variety of roofing styles. The integrated tempered double-glass structure ensures the safety of the roof structure. Featuring improved roof ventilation and heat dissipation, as well as fast installation, the Sunshine tiles can not only improve solar power generation efficiency, but also help households lower energy costs while reducing their overall carbon footprint.
Durable
Ultra Safety
Aesthetic
Rapid Installation
Modular Design
Fire Resistance
Ultra Safety
The integrated tempered double-glass structure provides better mechanical performance to protect cells from deformation by fire, wind, and rain, which helps ensure the safety of the roof structure.
Burning block test: 300*300*57mm 30min
Flame spread test: 10min <1.82m
Wind resistance test: Passed 50m/s
Rain test: Passed 9.5L/min
Durable
Sunshine has been certified as a building material and can be used directly for roofing. It is sturdy and durable, with a lifespan that matches that of the building.
Compliant with mandatory certification standards for building materials
Resulting in same life cycle as buildings
Aesthetic
Sunshine has a similar appearance and installation method to traditional tiles, with a variety of color options. Installing it on the roof will not compromise the overall aesthetic of the house.
Diverse colors
Compatible with traditional tiles
BMT-S1/032A(Ochre)
Size
1508×420×23.5mm
Power
129W/m²
Fire Test Rating
Class A
Waterproofing Method
Structural Waterproofing
Function configuration
Adapted to rapid shutdown, SunSpec compliant/ NEC2020-690.12 compliant
BMT-S1/032A (Ebony)
Size
1508×420×23.5mm
Power
170W/m²
Fire Test Rating
Class A
Installer
