HT Series
73-136 kW | Three Phase ∣ up to 12 MPPTs
Easy & quick config
Internal humidity monitoring
The HT 1100 Vdc Series 73-136 kW is GoodWe's new string inverter for C&I and small utility projects to boost your power and profit. Generate your solar power and make use of it with this centerpiece of the clean energy system. The HT Series seamlessly incorporates its technical strengths designed to achieve higher savings in the installation, enhance productivity with increased energy yields, realize high power density and diversify available monitoring options. It takes safety to the top possible level in accordance with the strictest industry standards and runs efficiently even under the harshest environmental conditions. This unrivalled set of features was conceived to ensure the lowest levelized cost of electricity (LCOE) to offer this ideal choice for commercial and industrial PV systems.
String level monitoring
Optional Type I Surge Protection & AFCI
IP66 and C5 protection
Easy & quick config
Superb Safety & Reliability
Equipped with IP66 and C5 protection, HT 100-136kW Series endures harsh environements for stable performance throughout its life cycle. Both the DC side and AC side are equipped with optional Type I surge protection to protect the inverter from lightning, providing upgraded safety and reliability for the PV system.
Optimal Generation for Higher Return
With the compatibility with bi-facial modules and maximum 15A DC input current per string,  HT can deliver comprehensive commercial energy yields for increased ROI.
45
Full load running at 45°C
2
Compatible with bi-facial modules
12
MPPTs
GW73KLV-HT
Max. Input Voltage (V):
800
12/2
Max. Efficiency :
98.4%
Nominal Output Voltage (V) :
220, 3L/N/PE or 3L/PE
GW75K-HT
10/2
Max. Efficiency :
98.6%
380/400, 3L/N/PE or 3L/PE
GW80K-HT
10/2
Max. Efficiency :
98.6%
GW100K-HT
10/2
Max. Efficiency :
98.6%
GW110K-HT
12/2
Max. Efficiency :
98.6%
GW120K-HT
12/2
Max. Efficiency :
98.6%
GW136K-HTH
12/2
Max. Efficiency :
99.0%
500, 3L/PE
Installer
