A-ES Series
5-9.6kW | Split Phase | Up to 4 MPPTs | Hybrid inverter (HV)
A-ES Series | GoodWe US
150% oversizing
AFCI
AC bypass
The GoodWe A-ES Series is a split-phase hybrid inverter designed to increase self-consumption of your generated solar energy. GoodWe A-ES is compatible with high voltage (80-495V) batteries with a power capacity ranging from 5 kW to 9.6 kW. With up to 4 MPPTs, the A-ES inverter seamlessly adapts to complex residential rooftops. Equipped with rapid battery charge functionality and perfectly capable of powering large loads in back-up mode (up to 9.6 kW).
Seamless UPS Switch Function
4 MPPTs & 150% DC Input Oversizing
AFCI & Rapid Shutdown
Smart Meter Integrated
150% oversizing
AFCI
AC bypass
Integrated AFCI & Rapid Shutdown
The GoodWe A-ES has been designed to meet the safety regulations of the American market, including Arc Fault Circuit Interrupter and Rapid Shutdown. GoodWe does not only deliver efficiency, reliability, but security as well.
Up to 4 MPPTs, the A-ES (5-9.6 kW) is the perfect solution to feed solar power to large residential properties, covering all the corners of your rooftop and maximizing total solar generation. With 150% DC input oversizing capability, the A-ES series is driven to its full capacity by extra reflections added to the back of bifacial panels, designed to increase power output even under low solar radiation.
4
UP TO 4 MPPTS
150%
DC INPUT OVERSIZING
GW5000A-ES
80~495
Max. Charging Current(A)
50
Max. Discharging Current (A)
50
Number of MPPTs / Strings per MPPT
Output Voltage Range (Vac)
211 to 264 @240
GW6000A-ES
80~495
50
50
211 to 264 @240
GW7000A-ES
80~495
50
50
4/1
211 to 264 @240
GW7600A-ES
80~495
50
50
4/1
211 to 264 @240
GW8600A-ES
80~495
50
50
4/1
211 to 264 @240
GW9600A-ES
80~495
50
50
4/1
211 to 264 @240
Installer
